Random restarts
jec1521
Hey, I have an x700 pro and it seems that every once in a while, my computer would restart after i hit the "quit" button in CS 1.6. And ONLY then, not while I'm playing. After restarting, it says the error was caused by a driver problem. I'm assuming it has something to do with my video card drivers. I also have the latest catalyst drivers.
Any suggestions?
Download driver cleaner; go to add/remove progs, uninstall your graphics drivers, run driver cleaner on them, reboot, install new drivers, reboot again.
Should fix it..but for a quick fix, ctrl alt del and end task 1.6 so it wont crash :)
