Random Reboots with Insane Error
Cattata
This problem has gone on for a while and I think I posted here once before and didn't solve the problem.
Every so often, it seems when I'm running multiple programs, my computer with come up with this blue screen saying that my system is being shut down to prevent hardware damage. Originally this was thought to be a memory problem so I ran memtest a couple of times and it said my ram was fine. I checked the event viewer and did some research on the error and said that it was associated with some USB software maker, but I don't have any of their software installed.
Event Viewer says this: Error code 000000a7, parameter1 00000280, parameter2 e30945c8, parameter3 86cb2541, parameter4 86cb2541.
The exact error message I am geting can be seen here.
My system specs:
AMD 2800+ @ 200x11.5
1 Gig Corsair Value Select pc 32000
Abit NF7-s rev.2
radeon 9800 se 128mb 256 bit
maxtor 120 gig hdd
Well the link you posted said something about lexar usb driver, my guess, if you don't have that, is it might be usb related though, trying unhooking all your usb stuff and see if you can get it to repeat.
