Random Lockups...
-zax-
Heres how it goes.
I recently upgraded my PC, and switched all my older equipment into my mom's PC. She was running an Athlon Thunderbird 900MHz, Tyan Trinity KT-A Mobo, 512MB Crucial PC133 ECC 2-3-3-6 T1 timings, and a Western Digital 7200RPM 40GB Hard Drive.
Her old setup had one flaw... it would randomly lock up. Didn't matter what she was doing, would just lock up. Most of the time, it would lock up when she wasn't even using it.
After I upgraded her PC, (which works fine now... no freezing :) ), I just swapped the older Processor, Mobo, Ram, and HD to another PC. I updated the BIOS on the mobo to the latest revision, as I found out that XP Pro was having some ACPI write problems when going through the event viewer. Got that problem fixed, but the darn thing still locks up.
One other weird thing is, whenever I try to copy some larger files/directories to the new HD from the old one, the PC will reboot automatically. When I go through the event viewer to see if an app or driver caused the issue, I find nothing.
It still locks up at random times regardless of what I do. I used Western Digitals DLGUtils to do basic and extended tests on the drive, but it finds absolutely nothing wrong.
Do you think I'm the victim of a faulty mobo, processor, or HD.
I have another 512MB of Crucial Non-ECC Ram @ 2-3-3-6 T1 that worked flawlessly in an older PC. I tried it out in the "freezing" PC, but it still locks up, so I dont think its a ram issue.
Any thoughts??
I had another PC that has been running off the same power supply for a long time...
The older processor was only 700MHz vs 900MHz, and it ran fine without any problems.
I also had the "culprit" in a different case which had a better power supply and it still did it regardless. Now I've got a 2200+ in that case and it runs smooth as silk.
Power supply is not the issue I believe. I'm thinking HD or Mobo. (Leaning more towards Mobo)
I've had a hand full of drives act up, never to be the cause of lock ups, They always never booted or would lose information. It sounds like the power on the vcore is jumping around causing it to lock up sometimes. If you can bump up the vcore a notch and see if that corrects it.... you ruled out the main areas, I'd say volt meter the psu but you've used different ones... rams also a good reason to lock up. but I doubt its the HD, so your down to MB or processor... try another processor, try reseating this one? I'm leaning toward motherboard....
I think i'll up the vcore in bios... if that doesn't work.. to hell with it. :)
Got a spare 2500+, Asus A7V8X-X, and 80GB WD SE drive coming my way to replace the equipment. Looks like I'll just have more parts laying around ...
