Specs:
Athlon 3200+
DFI Ultra Infinity
XFX Geforce 6800GT (Was overclocked to 410/1.1 but I reset the speeds to default after this started happening)
1GB Corsair XMS RAM
Antec 500watts PSU
Yesterday I had finished playing the Rome: Total War demo and was just about to leave for work when suddenly i heard a "beeeeeeeeeeeeeeeeeeeep" coming from my computer. I went to check it out and the computer was completely frozen. I didn't have time to investigate so I just turned it off with the power button and went to work. When I came back I turned it on again and it booted to the XP login screen but the mouse wasn't responding. I turned it off and on again and it worked perfectly for a few hours until it happened all over again. The third time it happened after 5 minutes and the fourth time it happened after about an hour. I've left it off since the fourth time. All the information on BIOS beeping is when the computer is jsut starting up, but this happens while the computer is running. Anyone know what the problem could be?
Recap:
1) Computer starts up and loads windows
2) I'll use the computer for X amount of time
3) It randomly locks up and makes one continuous beep after X amount of time has passed (X has ranged from 5 minutes to a few hours the 3 times it has happened after the first)
4) It now must be turned off via power button
5) After turning it back on, Windows loads up but the mouse doesn't respond
6) Computer must be turned off and on again
7) Windows loads up and the mouse responds
6) Go back to #2
EDIT: I just reseated everything and I'm up and running... I'll see if it happens again.
Athlon 3200+
DFI Ultra Infinity
1GB Corsair XMS RAM
Antec 500watts PSU
Recap:
6) Go back to #2
