Hi there folks, I need some help. I recently built my first computer, here is what I used:
DP35DP Intel Board
Q6600 Quad Core
EVGA 8800 GT
mushkin DDR2 800 2x2gb dual channel
600W PSU
xi-fi extreme gamer soundcard
vista 32-bit
samsung spinpoint t series 500gb hard drive
Basically, it ran fine for a few days, I have all drivers up to date, but then it started randomly freezing up! It has happened twice so far, apparently for no reason at all. I'm really clueless right now as to what might be causing it, can you guys help?
Also a secondary problem (nowhere near as important), whenever I start the thing up it takes about 2 minutes for any commands I enter/click/etc to register, but only right after I start up. After that it is fine, until it randomly freezes of course... but please help with the freezing problem first!
some more information:
processor- 44C Idle
motherboard - 41
I/O Controller Hub: 60
Memory Controller Hub: 67
I know the memory is at the correct voltage because the board only allows 1.8V, and I bought 1.8V memory because of that. I ran memtest86 overnight but when I came back, windows had loaded but there were no test results from the overnight tests..
So far it has frozen 3 times and at random times, I have no idea what could possibly be causing it. As I said, it worked fine for a couple days.
Please help! Thanks in advance.
edit: Oh, I am NOT overclocking.
edit 2: I just ran chkdsk... but when windows reloaded, just as memtest, it did not show any results! How am I supposed to see if there is a problem with them if I don't get test results?
DP35DP Intel Board
Q6600 Quad Core
EVGA 8800 GT
600W PSU
vista 32-bit
processor- 44C Idle
motherboard - 41
