Guys, I have been having a problem with a crash that occurs out of nowhere, for no reason, and its always at the most unexpected time! Of course, this is common, but I am here to fix the problem. The problem is, from what I can tell, is in just about any game I play (NEWER GAMES) is that it crashes to a BLUE screen, not the BSOD, just a blue screen with a heart wrenching screeching noise. I then have to shut off the computer and boot back up. Here is my current setup:
Lian Li pc-60
DFI Lanparty sli-dr nf4
Amd 3700+ 939 San Diego - with stock cooling
2x 1gb Patriot 2-3-2-5 running stock
Radeon X850XT pci-e 256mb running at stock
Western Digital 36.6gb 10k rpm HD
Sound Blaster Audigy - could this be the damn problem?
OCZ modstream 520wt psu
16x dvd-rw
4x 80mm blue led fans
Neatgear 108mbps wireless g card
Windows XP Pro with all updates and sp2 installed
Here are some pics, first off to show its not a heat problem, because I have tried with case on, and with side case off with a small room fan blowing into the case.
CPUZ specs
If you need anymore information, please feel free to ask. I thought this should be enough, but let me know.
Lian Li pc-60
16x dvd-rw
CPUZ specs
