I have just put together a brand new system (specs below) with a fresh install of WinXP Pro, SP2. but i keep getting one of two things: this BSOD, or just lock-ups. Both happen at completely random points. Sometimes after the machine has been on for hours, or days, sometimes when it just gets past the "welcome" screen after boot.
Here is the BSOD when it gives me one:
I've checked around, but no real solutions can be found. MS's KB article doesn't say much on how to fix it.
any ideas? thanks in advance...
Specs:
Asus A8N-E revision 2, bios 1008. (I have also tried with all other BIOSs. Drivers are 6.55. I have also tried the 6.66 drivers and they were very unstable)
AMD X2 4400+
2GB (1GB stick x 2) Corsair Value Select VS1GB400C3 (in first and third DIMM slots, A1 and B1)
BFG 7800GTX PCI-E (78.03 drivers from nvidia)
Antec TruePower 550 EPS12V SSI Server-rated PSU
Maxtor DiamondMax 10 SATA 200gb (on 1st SATA channel; have also tried on the other 3 channels)
Creative 52x CD-ROM (IDE Primary master)
Plextor 716AL DVD/CD burner (IDE, Secondary master)
Plextor 16/10/40A CD burner (IDE, Secondary slave)
Floppy drive
2 case fans + 1 CPU fan (AMD retail box HSF)
Windows XP Pro, SP2 (have also tried it with XP x64 Edition for a bit; problem persists)
-everything is running at stock speeds, no overclocking.
-Windows is completely updated (w/ SP2).
-I have not installed the nvidia IDE drivers, as people report more/other problems when using them.
-temps according to the bios are between 35-39 degrees (celcius).
-everything on auto in the bios except for ram which i bumped up to 2.75v.
-ran memtest86+ for about 2 hours, found no erros. i also switched out the ram for 2 other brands, problem didnt' go away.
-ran the diagnostic util for my Maxtor hdd, found no errors
Code:
MACHINE_CHECK_EXCEPTION
STOP: 0x0000009C
Specs:
AMD X2 4400+
Floppy drive
