Random computer troubles
l3ender
Hey guys, I had taken apart my computer to move, and I got moved in and tried to set it up only for the following to happen:
I get to my bootloader to choose either XP or Vista and I use the keyboard to choose an option (keyboard worked) and I hit enter. It then looks like it's going to start loading my choice but the screen just goes blank and the monitor blinks orange like it's in standby or something. I turn off the computer and mess w/ my video card (disconnect, re-seat). I was then able to get the display working again but it didn't even load the bootloader, it got stuck on startup junk. I restarted once again just to find that the display doesn't work once again.
The monitor works on a different computer.
Any ideas on what this might be?
Your card is not seated properly. Or, you've damaged the slot it was in somehow. Or the card. None of the options are great, but attempt to reseat it again and make sure any external power connectors (if it has them) are connected.
