So I decided to post in this section because 1) it has the most people 2) it may be a video card issue Im not sure.
First off I got a new computer with the following in it:
EVGA mobo
EVGA 8800 GTX superclocked
Core 2 Duo E6850
2 gigs of ram (Corsair i believe)
600 watt Thermaltake toughpower PSU
Vista 32 bit.
So I was playing HL Ep 2 and it froze once or twice the first time I had the AA at 16X next I took it off and beat the game and it never happened again. later on I overclocked my cpu max at 3.6 ghz than Crysis froze so I went back to default speeds. Than it kept freezing usually at random spots so I though it might be my GPU so I underclocked it it still did it. Now I have always had four fans and my temps are fine I think. CPU idles 30~40 load tops at 60 C maybe 70 but I doubt it.
My GPU idles at 58 ~ 63 and highest I have seen it get is in the high 70C maybe a little in the 80C I figure for the 8800 thats reasonable.
So the issue is lets say im playing Crysis and I through a grenade it will freeze or a huge explosion happens. But its random and sometimes it just happens when I am running. When it happened it HL Ep 2 it was totally random it just froze. So I have to do a hardboot and sometimes it gets stuck on the reboot screen like the BIOS. However if I let it sit for a little bit say 5 to 10 minutes it loads fine! I don't get this.
Lately when this happens and it reloads my mouse lags a little on the screen. And now sometimes if I load it up and it gets to windows but I didn't wait that long it will freeze while not playing a game like it will freeze on the web.
So first when it happened I thought it was vista using up all my memory or something but than I realized I had the hotfixed installed for that issue. Next like i said I thought it was an overheating issue but i dont think so. Now I am thinking its either GPU is just faulty or I am leaning to faulty power supply but I honestly don't know.
So I ask for any input on all your behalf's. Any input will be greatly appreciated.
EVGA mobo
Core 2 Duo E6850
Vista 32 bit.
