random 8gb of space HELP!
song
Hey all decided to reformat and reinstall vista however ran into a issue. I have 2 HD's and when i get to which partition does vista want to install to I have 8GB of unallocated space. Now I have no clue to where this came from because I can't combine it with my other unallocated space on my other HD's. When I highlight it, it also says "this computer's hardware may not support booting to this disk. Ensure that the disk's controller is enabled in the computer's BIOS menu." Now I never had this unallocated space before. It wont let me create a partition out of it.
I have no idea what could cause this to appear. I recently got a new DVD burner. Its a black LG 1 and I also installed a SQL database which im thinking maybe could of made a seperate partition. However it is unallocated space not a partition so i dont think thats the case. I just want to know what the hell it is. I have no usb flash drives/external HD's connected or anything. I am worried it could be a virus that attaches itself to a unallocated partition in secret or something because I can only see this when I try to reinstall windows.
1. I am sure this has nothingto do with a virus. (you can breathe a sigh of relief here)
-edited for clarity here. its not a virus, even though that would be pretty cool, if not useless.... a virus can't make use of unallocated space now can it-
2. what kind of hardware do you have? motherboard? hard drives? SATA or RAID volume?
3. What is your software configuration? Are your drives formatted NTFS?
4. Double check the jumper configuration of your hard drive, there are different settings that can interfere with traditional space allocation.
5. I would recommend downloading and booting a live CD of GpartEd http://gparted.sourceforge.net/ and seeing what information you can about this mystery unused space. It might even allow you to expand your partition into it. As always be sure to back up any important data before messing with partitions. -- and I also highly recommend unplugging any drives you are not tinkering with... mistakes are not so difficult to make.
If you're not someone who's been messing with your partitions much if at all the drive may have never been formatted properly to begin with. Also sometimes OEM manufacturers hide backup partitions on their drives, if this was deleted but never expanded into you could be seeing the side effects of that. too many other what ifs to say for sure but hopefully this helps. Try out GParted and report back.
I have 2 HD's 1 250gb and 1 TB and I have them in NTFS. I bought them new and completely wiped them before use. I reformatted 10+ times on them and never had this unallocated space. The bizzare thing is that vista states it is Disk 1. My 1TB HD is Disk 0 and my 250gb is Disk 2. I have no other drives reported in bios either other than my 2 HD's
I will look into that program tommorow or should say later today since its 2am. I am going to bed very soon thanks for ur hlp.
While this is bizzare, I imagine this space was overlooked at some point. ;) I think Gparted should paint a good picture for you of whats going on in there for ya. Most especially it should help you get it incorporated into a partition of some type. Let me know how it goes.
