formula409
- Apr 7, 2005
Here is the issue: 12GB's of G Skill Ram (two kits of 6BG triple channel memory PC1600 7-8-7-24 1.5v) Only 8GB's can bee seen by the motherboard and Windows 7.
Have confirmed both kits on there own are fine. CPU-z reports 12GB's in the electrical level they are seen. The setup is a RE3, i7 980x, 12GB's Gskill, 5970, Corsair 1000watt PSU and Corsair H50.
What I have done. Have set the RAM to 800, 1066, 1333, and 1600 Have let the BIOS Auto set the Ram and have manually set the timings. Tried both kits on the RE3 in the orange/red slots and saw 6GB's Added extra DIMM to first black slot to get 8GB's and other combinations but never mixed the 2 kits up.
Have reseated the Ram multiple times. Placed in different slots and a kit at a time which works fine. Each shows as 6GB's
Have reseated the CPU and re checked for bent pins and re seated the cooler. non bent or out of place. Have loosened the H50 retention bracket and tried from fairly loose to all the way tightened down.
Have cleared the CMOS and set BIOS defaults.
Have raised the DIMM voltage and QPI voltage.
Have raised CPU and IOH voltages and combinations of all.
I know its a common problem for the x58 platform to have. Following tips here on the forum and all over the net, i just cant see to get 12 GB's to show. Yes, 12 GB's is needed for the broadcast 3D and After Effects rendering I do. Most of the parts used to build the system have been waiting for up to a month just for the Rampage III to go on sale. Please, I really need some help. Thanks
