Apr 8, 2009 #1 R Ruachta n00b Joined Nov 14, 2006 Messages 59 My SB and NB temps seem to be high on my board. Just wondering if this is the norm. For some reason I seem to recall them being cooler. Currently temps during normal use: CPU 45C NB 55C SB 53C MB 41C i7 specs in sig. edit: Normal use is playing CoD4
Apr 8, 2009 #2 E E.R Gawd Joined Sep 19, 2007 Messages 631 Make some intakefan blowing on it and it will get lower but your temp is not that high.
Apr 8, 2009 #3 S soulesschild Supreme [H]ardness Joined Feb 18, 2007 Messages 6,176 Not too bad. My Rampage Formula used to get something like 60-70s when benching/stress testing :O
Apr 9, 2009 #4 R Ruachta n00b Joined Nov 14, 2006 Messages 59 Thanks for the replies. I think I'm gonna pick up a new case with a bit more air flow.
Apr 9, 2009 #5 D Dan_D Cat Can't Scratch It Joined Feb 9, 2002 Messages 66,323 A bit high, but nothing to be concerned about. As others have said, some better airflow might help some. Lower your ambient temperature if possible and if you can. That will help quite a bit.
