RAM wont work (in certain slots)
MDSarcasm
So, I just bought a DFi LanParty UT nf4 Ultra-D motherboard and tried to put my 2 sticks of generic RAM in dual-channel, which didnt work (I wasnt surprised) so I had to put them in the top 2 slots...
Until I got another 256mb stick, I put that in the 3rd slot and it wouldnt boot. So I took it out, then tried to put 1 512mb stick ONLY in the 3rd slot, and it wouldnt boot :( I then tried the 4th, same thing...and with the other 512mb and the 256mb, both wouldnt boot...
So Im wondering, what s supposed to be happening???Are my mobos slots shot?
Any help appreciated.
Well, you have to buy dual channel ram in order for dual channel to work.
Are you sure it's not just the RAM you're using? If you can, buy some RAM from a trusted brand, i.e. Corsair.
Ive tried all three RAM sticks I have in either slot 3 or 4, none work
this is VERY frustating
:mad:
Did you try putting the new stick in by itself, to make sure the stick works fine?
All three sticks work fine, Im pretty sure its not the RAM, as I said, they work (and are working) fine in slots 1 & 2
If they all work individually, that your motherboard is FUBARED, or your CPU's memory controller took a shit (eclipse, is that possible?).
Get in contact with (cf)eclipse, he'll help you out.
It also wouldn't hurt to ensure that your are running the current BIOS version. Maybe a newer BIOS could contain updated CPU microcode and memory support.
as long as the stciks are matched (same type,etc) - I have found that even generic ram works in dual mode - hell that is what i use.
update the bios - dfi boards have issues with certain kinds of ram, you may need to uopdate the bios - go in and change some settings with just 1 ram stick in there before both work.
check out www.dfi-street.com for more info
hope this helps - i had a hell of a time getting my ram to work on my SLI-DR Expert but now its perfect
you prob heard this before - "dfi nf4 boards very picky about ram" . especially corsair. but as long as you have 2 matching stix it should run. clear your cmos, and put 1 stick in the orange dimm slot that is farthest away from the cpu. then boot into your bios, set vdimm to 2.7v or 2.8v vdimm, and set all your ram timings to auto, use the ram speed setting to ensure that your ram is not overclocked, then save. put the other stick in the other orange slot, then stoke it up. if it doesnt work, try using the yellow slots. if that doesnt work, fish out your receipt and get yourself an rma number.
g.skill and ocz ram seems to work the best (compatibility-wise) with the ultra-d. but i also have had luck with very cheap a-data(v-data?) pc3200, which i was able to overclock to around 265mhz, cost around $70 per gb at newegg. board seems very choosy about corsair ram, so avoid it if possible. there is ram just as good/better for the same price/cheaper than corsair.
