Ram wont run slower than rated....
Sojuuk
anyways i got my second stick of corsair 512 3200 today. Stick it in turn the computer on and screen wont prompt. Well after letting the bios reset itself, I found that the ram wont run at 183mhz(275/1.5) which is what my old single stick did just fine i have yet to try turning off dual channel to see if thats what is affecting it. But any thoughts, rig is in sig.
ram timing = 2.5,3,3,6
and yeah not gettting right amount of andwidth, roughly 4700gb/s. i assume thats due to low timings.
that is regular timings
seems it will run at 166
and i think it is a bottleneck on my 865pe chip
says it wont run at 333 only 320 when in dual channel.
and im trying to make it run at 366 so a tad bit past that 320 thing
sounds bad to me, anyone else have thoughts?
OO just came to me... try putting it as only stick and then clocking it as high as it can go (prolly lower than it should be) and then run memtest and watch the errors fly!!!
~Adam
id run memtest if i could get to dos :\
little note:
found out my ram sticks aren't the EXACT same. one is rev1.1 the other 1.2.
corsair stuck it to me this time :p
ah come on 6months apart :-p money was tight.
but i can afford another stick if i need to now.
you might be able to
but as my win98se disc has taken a walk I can't
little note:
Corsair didn't stick it to you. You have 2 different chips there. v1.1 is BH-5 and v1.2 is CH-5. They just don't like working together. I ran into the same situation. I just sold that stuff and purchased a matched set. Problem solved.
i said it jokingly and i knew there was a likely hood of this happening, but i dont intend to sell my sticks just the old one and buy a new 1.2rev to run in pairs.
I know a guy who would be *very* interested in that first stick of RAM. He (diredesire) should be PM'ing you today about it.
actually i was hoping to get another bH5 :\
as the overclock like crazy as compared to the ass ch5
the asus does not read the spd correctly
go manual and set that stuff 2-3-2-6 -8 and rock on
id put it at those speeds if it would get into windows at those speeds.
most i can do is 2 3 3 5 8 other ones just wont budge :\
but on the single old stick i can run 2 2 2 5 no prob
guess they changed to em cause they sucked so much, prolly alot cheaper or something.
thanks vert, yeah.. if you want to sell it (or have to resort to doing that) leave me a PM :p
