First off I am working on overclocking, but seeing as I don't know how to for sure. I have been taking it slow. I'll try to include as much information as possible.
P4 3.2C@3.2 currently 1.6v, 200mhz fsb
Asus P4c800e-deluxe
Kingston HyperX PC3500 1gb (2x512mb)
Thermalright sp94, 92mm zalman fan
ok ram timings from Kingston say 2.5-3-3-7
I had it at 2.5-3-3-8 changed it to what they said and sisoftware sandra memory benchmark increased a little. Then some how when changing something in the bios it went to 2.5-3-3-6 I ran a test before changing it back.
2.5-3-3-6 = Int Buff 4843MB/s, Float Buff. 4855MB/s
2.5-3-3-7 = Int Buff 4558MB/s, Float Buff. 4555MB/s
Voltages are at auto.. not sure what voltage its running at.
Obviously the 6 is faster... but is that better? I mean they recommend 7 right? Should I keep it at 7 while I over clock the cpu?
Bottom line. How should I overclock? Start working with my cpu overclock then mess with ram?
Any advice, comments, questions will help so thank you. I'm sure I forgot somethng haha
Asus P4c800e-deluxe
