Ram Timing Advice for new build
Rumbled
Can anyone explain tightening and losening up ram? I'm currently running Kingston Hyper X 1600MHz with 9,9,9,27 at 1.65v recommended timing and voltage. Also would it be faster to run 1300MHz with the CPU-Z recommended JDEC of 9,9,9,25? Thanks for the advice....
Case: NZXT Phantom Black
Motherboard: GIGABYTE GA-890FXA-UD5
CPU: AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz
Heatsink: Coolmaster V8
RAM: Kingston Hyper X 1600MHz 9,9,9,27
Video Card: Radeon 1 GB HD 5570, Asus 1 GB 8400
PSU: Thermaltake 650 Watt
Storage: (2) Hitachi 1TB 7200 rpm Sata, Seagate 2 TB 5200 rpm ext
Speakers: Logitech THX 5.1
OS: Windows 7 Ultimate 64-bit
OC: 3817 MHz, 19X - 1.296V, NB 2400MHz
even in a benchmark program the difference between 9-9-9-25 and 9-9-9-27 probably wouldnt show up.
the RAM timings are numbers of clock cycles needed for a certain function. there are around 2 dozen numbers that effect RAM, but the main four (or sometimes 5; which have the most impact) are what you see in specifications.
this is what they actually mean http://en.wikipedia.org/wiki/Memory_timings
9-9-9-27 @1600 is definitely faster than 9-9-9-25 @ 1333 (~same timings, faster clocks)
You'd be hard-pressed to be able to tell the difference between a system running one versus the other, though, unless you were running a memory benchmark.
It's almost pointless to get super low-latency expensive RAM anymore.
