Ram slots not working
locutus24
Recently received my k8t neo2 939 motherboard (well not so recent, but it hasnt been a long time) Wondering if anybody could possibly explain why only 2/4 ram slots work, hasnt been a huge problem but just recently my friend (With a P4 2.4ghz 512k L2 cache 1gb ram x800gt) beat me in 3dmark right now my excuse is that my board is defective.
Please if anybody has had a similar situation with 2/4 ram slots working tell me what you did, if all else just point out the inevitable that i am going to have to get a new board (Need a reason for a new vid card and mobo cause pci express looks promising)
Sorry if this should be posted elsewhere like in the amd specific section
Not work as in the slots don't work at all? Or not work as in dual channel?
With the Neo2 the memory sticks have to both be in purple, both be in green, or use all four slots to run in dual channel mode.
If the slots don't even recognise the memory its a bad board, or a very bad memory incompadibility issue.
I have to use all 4 for dual channel :confused:
Ok new question what configuration do i need to do dual-channel on a 939 K8T Neo2 board
Right now a geil value stick, and a crosair stick are in green slots.
Dual Channel Clarification:
You can use the two green slots, OR the two purple slots, OR all four. Basically, the memory sticks are supposed to be right next to each other to run dual channel. It was a big cause of confusion with the Neo2.
As for your configuration, you might try the purple slots, but you really should be using matched pairs if you want to run dual channel.
