RAM question
FleetCom6
Hey, all. me and one of my friends are planning to manufacture a bare-bones computer case out of a tool box. yes, i know this has been done before, but we figured it would be a good first fabrication project and we need something to do over spring break. anywho, i pulled some RAM out of an old (2000) HP, and i dont know whether it will work with the mother board we have selected, which is the M7VKQ PRO from BioStar. you can also find the mobo here. now, the RAM i have is very cryptic, as it doesnt straight out tell whether it is DDR or anything like that. i was trusting that the [H] Gods may be able to help with this one. ok, one of the strips says "128 MB 161379 128 MB PC1002, then rambles on about Canada. the other says "MT4LSDT864AG-10EB1 PC100-222-620 SG CBNA7ZZ016 200021 64 MB, SYNCH, 100 MHz, CL2." Thank you for helping with this!
Don't think it'll work. Judging from that long string, it's PC100 RAM which won't fit into that mobo.
