Ram Question
carblow12
I have a question look like i can go 140 fsb with myt pc2100, like if i raise the mulitplier and not the fsb can i overclock well with pc-2100? B/c pc3200 cost way too much
You should be fine just raising the multiplier, but you'll miss the bandiwdth advantage of pushing the FSB.
WEll i would get pc3200 but it too expesnive for 1gig of ram and since i can't run pc2100 and pc3200 i mine as well buy another 512 so a gig of pc2100 then when i get the money get pc3200
Wrong. You can mix RAM speeds just fine. So, go and buy 512 of PC3200 now. I think everyone can agree that 1gig of 3200 stuff is expensive, but don't shoot yourself in the foot and buy outdated RAM right now.
Originally posted by carblow12
well if i get the pc3200 it will run at 266mhz and not 400mhz.....
why wouldnt you just throw it at 400 mhz immediatly and lower the multi, then raise the multi as you OC? even at the same total speed, with a higher FSB youll get much more performance, esp in the memory regions
