So i bought the ASUS M4A78T motherboard for my computer and read the manual to see which memory works with it so I bought the G Skill 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600, but the thing is that on newegg it says that my mobo supports 2 channel and my RAM is 3 channel, will I be able to use this RAM and how will it affect me.
RAM-http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225&cm_re=g_skill_ddr3_1600_6gb-_-20-231-225-_-Product
Mobo-http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366&cm_re=asus_m4a78t-e-_-13-131-366-_-Product
Thank You
Thank You
