2-2-2 2.5-2-2 2.5-2-3 2.5-3-3 3-3-3
2.6 216.46 250.51 258.84 268.68 295.17
2.7 219.48 253.54 263.38 273.22 299.71
2.8 224.02 258.08 266.41 277.00 302.73
2.9 226.29 260.35 269.43 279.27 304.25
3 229.32 262.62 273.22 283.81 305.76
3.1 231.59 264.89 275.49 287.60 305.00
ZL1 said:First - ram in dual channel is faster than single channel at any speeds
Second - well you oc ocz ram the same way you'd oc any other ram, by upping the mhz they run at, but since your ram already runs at higher speeds than your cpu fsb the only thing you can do to oc the ram is to mess with the timmings, if you have an option to do so in the bios, or to oc everything by raising the fsb, but in that case you need to watch the agp/pci ratios, cpu temps and psu voltages
how to test your stuff http://www.ocforums.com/showthread.php?t=418387
Merry Christmas !
D
SKy042 said:
hell yeah. it's gonna take a while till it rivals what my a64 oc guide looks like thoughHDBox2d1 said:"Now now, the where the real fun begins."
haha
thats alot of writing![]()
nah, it needs a bit of work still, and i want it to go in the memory forumMrSlacker said:(cf)Eclipse, that post alone deserves to be a sticky!
