RAM/OS or HDs?
ApocalypZ
Ok so i have three more wishlists im buying. im on a tight budget right now but im trying to figure out which set to buy first. Of course im buying from newegg.
SET A
WinXP Pro Full Version OEM - 139 (running home now)
Corsair XMS 512MB PC3200LL - 132(already have one of these)
Thermaltake Silent Boost for Athlon - 30 (have a loud volcano 10+ now)
Total - 300
SET B
WD Raptor 74.6GB 10,000RPM 8MB SATA - 252 (running maxtor 160gb 7200rpm 8mb IDE now)
WD 120GB 7200RPM 8MB SATA - 120
Total - 372
SET C (This will be the one i buy last)
Antec 480W SmartBlue PSU - 80 (350w antec smartblue now)
Coolermaster Blue Cathode - 10 (have one now, i want another)
Which would you recommend i get first?
my father will buy my xp home from me for 150 so i was like well ill just get pro and spend the last 10 bucks on candy.
Wow, he's gonna pay you more for home than you pay for Pro...
Well, if you're gonna be short an OS, I go with option 1, and you can run in dual channel too with the RAM. Option 2 only if you're sick with your current hard drive's performance and you just gotta get access times 3 ms shorter. Oh yeah, and 200 gigs basically.
