RAM limitation on A7V8X-X.
Lukes Wall
On Asus website, I read: "DDR400 (PC3200) Support
DDR400 (PC3200), the latest and fastest DDR memory standard, supports bandwidth up to 3.2GB/s to provide enhanced system performance. (Note: PC3200 Max. to 2 banks only; PC2700 Max. to 4 banks only)"
I have one 512MB PC3200 chip and I would like to add another one. Would I have to underclock them or I simply can't put another memory chip on it?
The motherboard's FSB is 333Mhz, can I install a 400Mhz CPU if I set the FSB and the memory to 333Mhz?
Thanks.
[edit] the memory is double-sided.
I have a computer with that board, but I fail to see why you would want to use it with a 400Mhz FSB cpu. Im not sure if it will work but unless you already have the board, I recommend its bigger brother the ASUS A7V600-X which is about the same price but can run the 400 mhz fsb.
The question about the ram also has me fooled. As you posted is says you can use 2 sticks of pc3200 or 4 sticks of pc2700 (actually it only has 3 slots for ram if I remember correctly). From what I understand if you underclock the PC3200 ram to PC2700, which it should make you do since your FSB is 333, I dont see a reason why you couldnt use 3 sticks of it. My guess is that put that thing about compatibility with PC3200 to let you know if you want to OC the fsb and use PC3200 ram 1:1, the mobo will let you if you only use 2 sticks of the higher clocked ram. Hope this makes sense, this is just my guess.
The motherboard only accept two banks of PC3200. According to a FAQ on Asus's website, a double sided memory stick counts as two banks, that's the problem.
