RAM help?
I am running a Asus A7n8x delux motherboard, currently only running 256ddr 2700,
i want to upgrade to a gig of RAM. i was going to take that chip out of there completly and replace it was (2) chips of 512DDR 2700.
my problem is deciding if
1 - 3200 is worth or or should i go 2700
2 - what make of ram: Corsair Value select, Kingston, or Crucial?
what do you all think? and what would you say i should get... i am getting sick of the 256 and need a boost!!!
Thanks for the help guys and girl
patrick
i would assume you have a 333fsb chip? :D
i'd personally go for the crucial ram. it has a tendancy to run at tighter timings than stock. my pc3200 stick of value ram i got from them was able to do 2-2-2 from the rated 3-3-3 timings :eek:
