Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
How much is sufficient? I have 2 x 512MB sticks right now, wondering if I'll see any difference if I upgrade to 2 x 1GB sticks. This will go into a (currently in the works) setup with an E8400/QXXXX running vmware/linux/smp and some gpu client(s).
Well i have an e8400 at stock running on 512mb generic ram. Couldn't wait for good ram to come in So far I'm getting around 1600ppd at stock speeds with 4 a1 cores running. If you run virtual machine on quad rig 2gb will suffice, just give each 512mb ram each and you should be fine
[H]ard|DCer of the Month - February 2007/January 2
A2 protiens need double the ram of the A1 protiens.
So its upto around 800Mb min now if you want to get them.
The GPU client only uses around 50Mb.
So with a couple of VM's and a GPU then 2Gb is the min I'd run to get max PpD.
