Ram for a Q6600
Anpu
Hey guys, I was just wondering what speed of memory I should use (DDR2 800 or DDR2 1066) if im going to oc the Q6600 to about 3ghz or 3.2ghz?
Thanks
Thanks will get that then. Any thoughts on the OCZ 2 x 2gb Reapers DDR2 1066 vs the Corsair 2 x 2GB Dominator DDR2 1066?
Erm, DDR2-800MHz is all you need. That will allow an overclock of up to 3.6GHz (800/2 = 400MHz FSB * 9 multiplier = 3.6GHz).
Well, I've read some good things about the Reapers but I have never personally used them. However, I DO run the Corsair Dominators (8500C5D's) 1066mhz modules. They are awesome! I am extremely impressed with the Dominators!
I'll pick option C: DDR2-1000. That'll allow for a much higher FSB than you can hope for with that Q6600, and a 4GB kit (2x2GB) of it is less than $100.
Alright cool, I currently am using the DDR2 800 Reapers, they are nice, but i am going to throw them into a development server. I was curious when I saw the Dominators 4 GB modules released at 8500.
I currently have my HTPC running my Q6600 and some Dominators running a 1:1 ratio at 1000mhz (even though they are 1066mhz modules)
You can always run higher rated ram so it will run cooler if you wanted to. You'd pay more and the only gain may be lower temp ram modules. But hey, it's your money.
Why buy 1066 when you can run 400x9 = 3.6Ghz on DDR800 at 1:1? You're not going to get much past there without watercooling anyway.
Very true; I forget not everyone is running water.
I still stand behind those sticks though; they're great value..
Alright so would you guys just advise sticking to the DDR2 800 Reapers?
In my opinion that makes no sense because the G.Skill rated at DDR2-1000 (which would allow you to drop the multiplier and go for a higher RAM speed than the 800 without worrying about whether your RAM will hit speeds >400FSB) and is the same price as that OCZ Reaper kit.
