SEE POST #8
Well I new this would had to happen to me someday.
As some of you might know I had just updated my PC with P6T deluxe V2, i7 920 & 6GB DDR3 1600 RAM.
I had tried OC this system last night, but wasn't very successful. I did a MemTest 86 v2.11 and it had failed after a few min. I was able to narrow it down to a single ram stick.
Since this build is very different from all other builds I did, i just want to check if I did the memtest correctly. I had BCLK set to 133 in BIOS (standard) and had my RAM volts set to 1.64v as well as C1 disabled. MemTest was standard.
I don't have much XP with newegg RMA procedures, how exactly will this work? Will they resend me an entire set or just 1 stick?
Thanks.
Thanks.
