Hello
I'm running this ram in this link
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
they are plugged into this motherboard
EVGA LGA 1366 Intel X58 ATX X58 SLI LE
And well during the summer time we had two big storms that knocked off the power to our home and well ever since then, my ram has been hit with memory errors, two of the three sticks have some errors on them, I do get some BSOD but have not had any in the past few weeks, but i can tell the PC is not running like it should be and i pretty sure its due to the ram. i have ran memtest and memtest 86 and they both are showing errors, so im pretty sure its my ram.
However I see the G skill guys says that should have 1.6V, Do you all think its worth trying to raise the volts to 1.6 and see if that helps or just buy new ram and be done with it?
