I am contemplaying adding some more ram to this. It is on sale at NE, and is a very good deal. I am worried, however, that there will be a conflict between the new ram, and the old 512 stick. Can anyone tell me one way or the other? Thank you
Current RAM:
"Crucial Technology 512MB 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) System Memory - OEM"
Brand: Crucial Technology
Model: CT6464Z40B.8T
Type: 184-Pin DDR SDRAM
Capacity: 512MB
Speed: DDR 400 (PC 3200)
Cas Latency: 3
Voltage: 2.6V
ECC: No
Buffered/Registered: Unbuffered
Heat Spreader: No
Possible New Added RAM:
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model TWINX2048-3200 - Retail
Brand: CORSAIR
Series: XMS
Model: TWINX2048-3200
Capacity: 2GB (2 x 1GB)
Cas Latency: 3
Timing: 3-3-3-8
Voltage: 2.6V
ECC: No
Heat Spreader: Yes
Also... is there any difference between that first set of corsair ram, and this one? (It is only $1 less):
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model TwinX2048-3200PT - Retail
Brand: CORSAIR
Series: XMS
Model: TwinX2048-3200PT
Cas Latency: 3
Timing: 3-3-3-8
Voltage: 2.6V
ECC: No
Heat Spreader: Yes
So, hehe, any difference between the 2 Corsair ram setups? And would there be a conflict between them and my current crucial ram? Thank you
Comp Specs:
ABIT AN8-V Socket 939 NVIDIA nForce4 ATX AMD Motherboard
Radeon X800 256MB DDR PCI Express x16 Video Card
AMD Athlon 64 3000+ Venice 2000MHz HT Socket 939
Crucial Technology 512MB 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory.
Maxtor DiamondMax 200GB 7200 RPM Serial ATA150 Hard Drive
Current RAM:
Capacity: 512MB
Cas Latency: 3
Voltage: 2.6V
ECC: No
Heat Spreader: No
Brand: CORSAIR
Series: XMS
Cas Latency: 3
Timing: 3-3-3-8
Voltage: 2.6V
ECC: No
Heat Spreader: Yes
Brand: CORSAIR
Series: XMS
Cas Latency: 3
Timing: 3-3-3-8
Voltage: 2.6V
ECC: No
Heat Spreader: Yes
Comp Specs:
