Hey guys,
A friend is building a new system, got all his parts off E-bay. He just asked me now if his ram and motherboard are Compatible, and i really have no clue.. if someone could tell me if they are and explain how you know that would be great.
Mobo:
AOpen 865PE Chipset Motherboard for Intel Socket 478 CPU, Model "AX4SPE-Max" -RETAIL
Specifications:
Supported CPU: Socket 478 Intel Pentium 4 Processors(Hyper-Threading)
Chipset: Intel 865PE + ICH5R
FSB: 800/533/400MHz
RAM: 4x DIMM support Dual Channel DDR400 Max 4GB
IDE: 2x UltraDMA 100 up to 4 Devices
Slots: 1x AGP 8X, 6x PCI
Ports: 2xPS2,1xLPT,2xCOM,8xUSB2.0(Rear 6),1xLAN,Audio Ports
Onboard Audio: Realtek ALC650 6-Channel AC97 Codec
Onboard LAN: Broadcom 5705 10/100/1000Mbps
Onboard SATA: 4x Serial ATA
Onboard 1394: Agere 1394 controller, 2 ports more info>
N82E16813137033
Ram:
Kingston ValueRAM 184 Pin 256MB DDR PC-3200 - Retail
Specification
Manufacturer: Kingston
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 3
Support Voltage: 2.6V
Bandwidth: 3.2GB/s
Organization: 32M x 64 -Bit
Sorry if this is in the wrong spot, but i think this was right.. also i think where it says speed: ddr400(pc3200) is where you know it will work, but i want to make sure im correct.
Mobo:
Specifications:
FSB: 800/533/400MHz
N82E16813137033
Ram:
Specification
Cas Latency: 3
Bandwidth: 3.2GB/s
