Firewalker81
- Nov 28, 2008
Does the amount of ram you have change the temperature your cpu will operate at?
no not really. maybe add 1-2C at most unless you are overclocking the ram and are required to add more voltage to the northbridge(IMC) which can then increase the temp on the cpu. but thats about the only reason the temps would increase.
