I am looking to pair the Asus P8P67 with a Core i7 2600K and am struggling a bit on the memory as am a bit hazy on the subject. I was going to aim for Corsair XMS3 6GB (3x2GB) DDR3 1600MHz: -
http://www.overclockers.co.uk/showproduct.php?prodid=MY-205-CS
it says this memory runs at 1.6 which is higher than the suggested 1.5 for the motherboard, is that an issue or can the voltage be adjusted. Im not sure about that stuff.
Also does this build seem like a good idea for gaming purposes?
Thanks for any advice
