Any way i can push my LCD monitor past the 1280 cap supported by the drivers?
If i try to manually push it, i have to scroll with my mouse over to side to show the full screen. Sort of like cropping.
I would guess you have 17" or 19" lcd that has a native res of 1280x1024. If that is true, then NO, there is no way to force a higher res. That is it's max res. If you set the res above that it will still only give you 1280x1024 but have the screen scrolling you are experiencing. If you set the res below native res, lcd monitors tend to look blurry or fuzzy or just generally like ass. Sorry if this is of no help.
Sorry bud but LCDs have a fixed number of pixels (i.e. their native resolution). They have no ability to display anything at a higher resolution than that. Physically unpossible.
