rainbow vegas what the hell......
pow64
after reading fourms trying to decide if i should shell out the money required i did.. because all i heard was how great the game was....but what the fuck........six 3 raven shield was way better. maybe im just a picky gamer but from the 10 times iv played it hopeing its gotten better it hasnt.
1st no peak? yes i know you can "cover" behind walls but what about when you swing wide and want to peak out?
2nd no auto shotguns only pumps.. if theres more then 1 person in the room your going into your done
3 too much camera shake/blurr...are they trying to simulate real gunfights? because after my 3rd tour in Iraq it dosnt happen..
4 unable to get highcaps/silencers? or did i just not figure out the controlls to apply them to my weapon?
5 whats with the weapon selection? 6 subs 4 LMG 9 assault 4 shotguns 4 sniper rifles and the abbilitys really set them apart let me tell you.....between 1 to 10 bars on accuracy damage and range most guns being the same rateings???? i remember back in ravenshild you had 1-100 on accuracy range damage recoil and something else with a total of 57 weapons
6 no prone? for waiting on people to come around corners? why would you have a LMG if you cant go prone or even a sniper rifle
7 its such a choppy game to play just listening to the sounds is agrovating although its awsome that they curse....but what i hear is tha tha that bitch owes me money and d d d die as well as where where did did he go go they just couldnt dis dis disapear.....do they have speach inpedements on everyone elses systems? or is it just me? how do i fix them?
8 agean with the choppyness there is almost little to no point in playing if you dont have the settings on high. everything blends into everything else and almost no ability to change options...sound quality? bla bla bla
there are so many other complaints to this game but i will save them for laiter..
its an ok game but its like UBI has went very very far backwords from ravenshield
There aren't many options to change, but if you want to turn that blurry, motion blurr type things off, you can with .ini changes. I posted it up before on many similar "Rainbow Six lags/sux" type posts. You can search for those if you want too. And actually, you can have silencers on almost all weapons except shotguns and sniper rifles. You had to hold a button to select, (action button? i changed it to "e"), similar to how you change grenades. Hi-caps are only avaliable on pistols. I wished they had more weapons/upgrades to select from. Multiple upgrades would be even more fun
I believe that when you are only playing by yourself, it is REALLY boring. Fortunately, I played through the campaign with my little bro. Freaken awesome. Even though we didnt really understand the story. We just had an awesome time killing terrorists together (bonding moment :D )
to get silencers, hold down the reload key and a menu will come up and just move your mouse in the direction where the silencer is and boom, you have a silencer. to get hicaps, when you are at a equiment thing where you can change your weapons, press c to customize your weapons and one of them should be hicap magazine. although i think this is only for pistols.
But....but...it's extreme....and....explosions....short attention span...watered down....that's what people like....right?
PS: R6 has been just a disaster for the past few years.
1.) There is an automatic shotgun.
2.) Peek is effectively replaced by cover. It works better once you get used to it.
3.) The new squad control systems make the game much less cumbersome to play.
3.) Personally, I think it is a lot more fun than the previous versions. Fun is what games are all about.
ahhhh ...little picky here aren't we? I actually really like this game, not ground-breaking with "all the features" but dam, just quit noticing all the small negatives, play it and have fun. Gheeesh!
