Hello,
I've recently set-up a ZFS box using 23 x 4TB Hitachi drives in RaidZ3
According to this calculator:
http://www.servethehome.com/raid-calculator/
the expected size of the pool should be about 72.8TB (taking in consideration the 3 drives lost for parity and the conversion between 1000 and 1024 - TB/TiB)
However, I am only getting 65.7TB...
This is the listing showing the available space (removed some unrelated information):
This is my pool with 23 x 4TB drives:
Can anyone more experienced with ZFS tell me what is going on?
Where is the ~9TB lost space? Is it reserved for snapshots, or anything else? Can I recover it?
thanks a lot,
-Marcus
root@openindiana:~# zfs list
NAME USED AVAIL REFER MOUNTPOINT
Pool-Storage1 65.7T 2.85G 460K /Pool-Storage1
Pool-Storage1/Volume-Storage1 65.7T 65.7T 230K -
rpool 16.8G 2.78G 47K /rpool
Pool-Storage1 5000 14237568027059623914 vdevs: 1
vdev 1: raidz3 12 92.02 TB 12843423673337650988
c10t5000CCA22EC008ADd0 11897191478853965569 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec008ad:a
id1,sd@n5000cca22ec008ad/a
PL1310LAG029NA
c10t5000CCA22EC00A7Cd0 4700561813297779659 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec00a7c:a
id1,sd@n5000cca22ec00a7c/a
PL1310LAG02TLA
c10t5000CCA22EC00F4Fd0 18078600867002041605 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec00f4f:a
id1,sd@n5000cca22ec00f4f/a
PL1310LAG042EA
c10t5000CCA22EC01A8Dd0 17529955265994712780 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec01a8d:a
id1,sd@n5000cca22ec01a8d/a
PL1310LAG0728A
c10t5000CCA22EC0210Ed0 521233862270374400 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec0210e:a
id1,sd@n5000cca22ec0210e/a
PL1310LAG08TZA
c10t5000CCA22EC021D9d0 16504663500950716529 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec021d9:a
id1,sd@n5000cca22ec021d9/a
PL1310LAG090JA
c10t5000CCA22EC02208d0 17286534736261518309 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec02208:a
id1,sd@n5000cca22ec02208/a
PL1310LAG0921A
c10t5000CCA22EC0221Bd0 11471414523034938154 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec0221b:a
id1,sd@n5000cca22ec0221b/a
PL1310LAG092NA
c10t5000CCA22EC0222Bd0 10137454426417349138 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec0222b:a
id1,sd@n5000cca22ec0222b/a
PL1310LAG0935A
c10t5000CCA22EC02234d0 9661598762332469726 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec02234:a
id1,sd@n5000cca22ec02234/a
PL1310LAG093GA
c10t5000CCA22EC02287d0 2707340434424007771 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec02287:a
id1,sd@n5000cca22ec02287/a
PL1310LAG0964A
c10t5000CCA22EC022ACd0 1409056393389450611 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec022ac:a
id1,sd@n5000cca22ec022ac/a
PL1310LAG097AA
c10t5000CCA22EC022E7d0 13341020487462083677 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec022e7:a
id1,sd@n5000cca22ec022e7/a
PL1310LAG0997A
c10t5000CCA22EC02D19d0 7239933575572325830 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec02d19:a
id1,sd@n5000cca22ec02d19/a
PL1310LAG0D0EA
c10t5000CCA22EC032E8d0 11341704217867462188 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec032e8:a
id1,sd@n5000cca22ec032e8/a
PL1310LAG0EKDA
c10t5000CCA22EC032F8d0 14003683354051041944 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec032f8:a
id1,sd@n5000cca22ec032f8/a
PL1310LAG0EKXA
c10t5000CCA22EC0330Bd0 15602634426552806117 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec0330b:a
id1,sd@n5000cca22ec0330b/a
PL1310LAG0ELJA
c10t5000CCA22EC0340Bd0 1306860508072491531 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec0340b:a
id1,sd@n5000cca22ec0340b/a
PL1310LAG0EVTA
c10t5000CCA22EC04C15d0 16571289578325581979 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec04c15:a
id1,sd@n5000cca22ec04c15/a
PL1310LAG0N89A
c10t5000CCA22EC04C26d0 14950040610680530891 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec04c26:a
id1,sd@n5000cca22ec04c26/a
PL1310LAG0N8VA
c10t5000CCA22EC04C35d0 6692930116809901728 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec04c35:a
id1,sd@n5000cca22ec04c35/a
PL1310LAG0N9AA
c10t5000CCA22EC04C48d0 10360558934820987983 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec04c48:a
id1,sd@n5000cca22ec04c48/a
PL1310LAG0N9YA
c10t5000CCA22EC04C87d0 5707996551731273821 Hitachi HDS5C404
/scsi_vhci/disk@g5000cca22ec04c87:a
id1,sd@n5000cca22ec04c87/a
PL1310LAG0NBZA
thanks a lot,
-Marcus
