RaidZ1 question
Xenner
Guys,
Putting the finishing touches on my ESXi/ZFS box.
I have it up and running with 3x2tb Seagate drives (got them on Craigslist for $70 each still in warranty, can't beat that price.) Problem is for me to get a 4th, it would be ridiculously expensive.
I do have a 1.5TB Samsung drive sitting around here..would it be wise for me to just do a 4 drive raidz1 vs a 3 drive...
right now with the 3x2tb drives I have 3.2TB useable space after the 90% cap. If I went with the 4 drive setup (only using 1.5tb on each 2tb drive) I would be at 4.05TB, and then if I was to find another seagate drive, I could pull the 1.5, rebuild the array with all 2TB drives and expand it out to 5.4TB, is this correct?
Thanks,
correct.
But if you do not need max capacity, consider Raid-10
2 + 2 TB
1,5 + 2 TB
gives you 3,5 TB but with much better I/O performance
Next disk should be a 2 TB hotfix for better reliabilty
You can increase capacity and performance easily by adding more 2 TB mirrors
So that would be two different vdevs? I would just add them to the same pool and it would act exactly the same??
ZFS stores data on a pool. A pool consists of one or more vdevs.
Each new vdev adds not only capacity to a pool but also performance.
The more vdevs you have the better.
A pool from a single Raid-Z vdev with a lot of disks is only good if you
mainly need max capacity. I/O performance is as good (bad) as a single disk.
