InvisiBill
- Jan 2, 2003
http://www.enterprisestorageforum.com/technology/features/article.php/3839636
A lot of people here already know all this, but the article does a good job of showing the math behind the problem. Drives are getting more dense at a faster rate than improvements in reliability and speed are happening. This is increasing the chance of data loss, due to longer times where the array is unprotected.
The concept of parity-based RAID (levels 3, 5 and 6) is now pretty old in technological terms, and the technology's limitations will become pretty clear in the not-too-distant future and are probably obvious to some users already. In my opinion, RAID-6 is a reliability Band Aid for RAID-5, and going from one parity drive to two is simply delaying the inevitable.
The bottom line is this: Disk density has increased far more than performance and hard error rates haven't changed much, creating much greater RAID rebuild times and a much higher risk of data loss. In short, it's a scenario that will eventually require a solution, if not a whole new way of storing and protecting data.
That means that in a perfect world using vendor specifications, we can expect one out of every 312 rebuilds to fail today with data loss. Moving to the next-generation 2 TB drives, this value drops to every 234 rebuilds, and with 4 TB drives it drops to every 117 rebuilds.
