Raidmax Smilodon -VS- Antec 900
Mr_Scary
Raidmax Smilodon .VS. Antec 900
Looks like the Smilodon now has a 120mm fan in the rear
check the specs, picture still shows an 80mm fan
Which case is Better?
Raidmax Smilodon Dirk-Tooth -
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156063
Or the
Antec 900 -
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
Antec 900 has lots of fans
2 front 120mm
1 rear 120mm
1 top 120mm
Please voice your opinion. I will be buying my setup this week, just need to know if anyone has expirience these 2 cases.
Thanks
Ur links dont work, my brothers about to build a new pc and hes looking at the raidmax (im trying to talk him out of it as he thinks the lights are cool now until he trys sleeping with them)
This shouldn't even be a question Antec 900 (yes i know i own a smilodon)
thanks guys, I think I will go with Antec 900, looks like a lot of problems might occer with smilodon, plu I think the 900 will keep my Q6600 kool when overclocking..
I saw a video of a guy showing off his PC & he had tape on the door of the smilodon.
I do like the removable mobo tray through...
However like even more the 900 removeable bays.
the top fan on the 900 is 200mm, not 120mm. antec is the only company to make a fan in that size AFAIK. it's a great exhaust fan, really. i keep it at max speed and it doesn't make the slightest sound, but still moves lots of air due to its size.
That Smilodon case looks like utter dog puke mixed with crap.
I've seen better looking cases in the toilet bowl 6 hours after eating taco bell.
I had the Raidmax for about a month. I wouldn't recommend it. It's not horrible, but the 80mm fan in the back is just not good.
I am now looking at Antec 900. Alot better.
ive had both, the 900 is better, i actually thought the smilodon wasnt bad at all for a regular pc but if ur trying to fit big heatsinks in and load it up then the 900 is gonna be FAR better.
