RaidMax Scorpio 868 Case question..
AboveAll
Hey Guys.
I got recently that case and I tried to connect the front panel audio to the board.
The problem is that I noticed that all the manuall and guides have 3 wires for the microphone which are MIC-VCC, MIC-DATA and GND and the headset got 4 wires for EAR R1, EAR R2, EAR L1, EAR L2.
That case has only MIC DATA and GND, and 2 out of 4 for the headset wires..thats EAR R1 and EAR L1.
So how exactly am I supposed to connect these to the motherboard with missing wires omg? Is it possible?
My board by the way is an EPOX 8KDA3J . I did quite a research all I could find on the knowledge base of epox is that document file...It shows clearly where to put what...but I still have missing wires..
Thats the link to the document:Doc file .
I will greatly appriciate ANY help im desperate.
Thanks guys :)
mic VCC is only used when need so since you don't have it leave it off.
As for the other 2 I'd say connect the ones you have and try it? if it doesn't work there's only 12 combinations.
