LBFlashWiz
- Oct 12, 2004
I have a 6-disk RAID5 on my workstation using a Raidcore BC4000 8-port card and 6 WD2000JD drives. This is the new BC card where I THOUGHT the drive dropping issues has been fixed)
This morning I had the alarm go off saying I have lost 2 drives on channels 0 and 1. This sent my Raid5 offline and I went to take a closer look at my two offline drives. I was not hearing any noise usually found when a hard drive dies and I was able to check the S.M.A.R.T status & performace tests with some low level disk tools and they checked out ok on my motherboard SATA port.
When I initially boot up, the first two HD access lights on the card are solid, while the rest quickly check the others.
I am almost positive that my drives are still ok. The odds of two drives (that have been online since June) going out at the same time are very small. I feel this is a card issue and have critical data on my raid5 that I would prefer not to loose.
Is there anything I can do so that I may keep my data?
Has anyone else had channel drop on them like this (channels 0+1)?
Has anyone ever recieved a responce from support through RAIDCORE?
Please help...
Please help...
