raid6 sata hardware card
sdadept
I need recommendations for a new pcie raid card for a high use home server. I plan to put 5 1tb wd black drives on it. The server will be running 3 virtual machines (I plan to try to use ESXi as the VM base) so the card needs to support full NCQ and be able to handle the occassional heavy load.
For what purposes?
Why 3 virtual machines? What are you up to?
3 vm's. I'm going to run home server on one (for my home network), then I'm going to consolidate 2 'development' servers (svn, finalbuidler, etc.) down onto the VM and get it out of my co-location rack. The 2 development servers are for companies that only have 4 or 5 developers and thus most of the time are idle (only really crunch when they are doing a build). With the new comcast home business service, I can run those from home. Potentially all 3 servers could be hitting the disk hard at once, especially if im streaming movies from the home server while doing a build or some such. So I want the hard drive performance to be tops.
Maybe today, "hot deals" had a RocketRaid4320 $620 approx >> $330 approx. sale. Or,
someone linked to it from a thread. Not to specifically recommend it over 3ware or Areca.
I'm really confused now. I only see a couple ports on the SAS card. Does SAS allow chaining or something?
SFF-8087 connectors are pretty much the standard for SAS cards these days. One multilane port is equal to four drives. Also, SAS allows for the use of expanders.
