A couple of days ago I knew absolutely nothing about storage arrays, so I have been reading here to equip myself with a basic understanding of RAID setups and what will suit my usage patterns. Now I am ready to purchase the first parts (HDs in august, since I am heading to the US at that point), and would like your opinion.
I primarily work with four types of tasks. 1: Loading (viewing) and adjusting hundreds of 15-25MB files with Lightroom. 2: Creating complex Photoshop files, often above 1GB. 3: Compositing and video editing.
Data Security is important and so is the gained read/write speeds, so I figure I need RAID5. I am not ready to sacrifice the performance loss in going RAID6, nor the space.
Forgive my potentially silly question and ignorance with network setups, but I am considering making this disk array a NAS. This instead of throwing it in my workstation avoiding the heat and noise. Does that make sense? A Gigabit connection will only carry 125MB pr. second as far as I understand, so my question is this; Is that enough throughput with 5 x 1TB SATA drives in RAID5? I have no idea what their throughput is going to be, sustained. SATA I theoretical limit is 1.2 Gbit uncoded I see..
I am aware that I am not going to benefit from the full potential of the SATA II drives due to these limitations, but is it an acceptable loss or ludicris? Will there be an unacceptable latency working from a NAS like I am settin gup here, with my type of usage? Do the component match?
DRIVES:
5 x 1TB drives, undecided. Leaning towards: Hitachi 7K1000 or Seagate ES.2
SWITCH:
NETGEAR FS726TP 10/100Mbps + 1000Mbps
http://www.newegg.com/Product/Product.aspx?Item=N82E16833122077
or
3com 3C1670800B 10/100/1000Mbps OfficeConnect Gigabit Switch 8
http://www.newegg.com/Product/Product.aspx?Item=N82E16833105136
CONTROLLER:
3ware 9550SXU-8LP 64bit/133MHz PCI-X SATA II RAID RoHS Controller Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16816116054
ENCLOSURE:
Supermicro CSE M35T (fitted in a Lian Li PC82)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121405
...SATAII compatible, but disks will be detected as SATA I.
I assume the controller is backwards compatible, and chose a SATA II controller to go with the drives, should I decide not to go with the cheap Supermicro enclosure. I am really unsure about that component still. The controller card is probably overkill, but I want a good card that I can use with an 8 disk array later on, outside the Supermicro.
Any feedback is appreciated. A simple thumbs up or a "you are insane you got it all wrong" would be great. Be gentle please, I am totally new to all this
DRIVES:
SWITCH:
or
CONTROLLER:
ENCLOSURE:
