I've assembled basic server using a Highpoint 2310. (asus P5K-V, E8400, 4GB, Server2003 Standard Edition)
The goal was to run Raid1 with two SATA drives. Have one drive in the case, three drives in enclosures with one 5.25 hotswap bay in the case.
Then, as a portable backup remove a drive and swap for another one every now and then.
The issue I'm having, is that upon inserting a "blank" drive for the first time the array will rebuild. But then, after swapping every drive once, the computer sees "two" arrays.... and won't automatically rebuild. I can manually delete the "obsolete" array and add the drive to the "good" array. But this is inconvenient (I won't always be the one swapping the drives).
The card's bios doesn't show me much. I've tried not using the management software in windows to see if card only would work but I get no feedback on if it's actually rebuilding. Until I've used all the blank drives then the bios shows "2" arrays name identically.
My questions would be:
-what am I missing?
-would a different sata/raid card change anything?
Thanks,
-what am I missing?
Thanks,
