RAID0 SSD for Program/Data drive or stay with mechanical?
ShepsCrook
I use my main computer for Gaming 98% of the time, and photoshop and web design 2% of the time. I currently have 1x Transcend 256GB 320 SSD for OS and 2x WD640AALS SATA2 drives in RAID0 for programs and data.
My motherboard is a Gigabyte GA-X79-UD3R.
I am going to replace my OS drive to the Samsung 840 Pro 256GB, however I my debate is whether I should pick up another Sandisk Ultra 256GB to RAID0 with the one I have sitting around and have those as my RAID0 Program/Data drives with the 840 Pro as my OS drive.
OR
I just pick up 2x 1TB WD Black SATA3 mechanical drives and use those for the RAID0 setup.
Other things things to consider:
I have a server with 16TB of free HD space so I don't need storage.
I only play a select few games (Left 4 Dead 2, Dead Island, Ultima Online) so I don't use up a lot of storage for game data.
Yeah, but why bother with RAID0 at all ?
Don't forget backups.
Practically I would say that a SSD alone is fast enough for all your needs.
personally if you have the cash I would do a RAID0 for games just for fun/overkill
What would be the reason for not using SSDs? Even if your SATA controller didn't support RAID + TRIM, I'd still use SSDs. Although if not your OS drive I guess you can just use Window's built in raid and then you could still get TRIM.
Yeah, I'm thinking I'm going to move to pure SSD
Now I just need to get a set of the SAME SSDs.
If there were any PCI based SSD's that weren't OCZ, I'd actually consider it. lol
Why not just reuse the ssd's you have for programs/data and forget about raid? I really doubt the difference will be perceptible moving from ssd > raid0 ssd.
I'd say yes..
but backup to the HDDs you have regularly.
Forget it if they're Sandforce drives..They die.
If it's them 840 Pros in your sig..definitely!
Earlier SF controller had few problems relating to firmware. Its all good with the latest series of SF based SSDs. As a general rule of thumb, we will need to make sure any SSD for that matter is having the latest firmwares.
If there were any PCIe based SSDs that were actually a PCIe based SSD and did not cost an arm and a leg. OCZs stuff was not PCIe based. It was internally a cheap SATA raid controller attached to SATA SSDs. You could do much better with LSI MegaRaid + FastPath if you were going that route.
