- Mar 31, 2005
Ok,
So ive decided I want to try to setup a RAID0 array.. This is the first time ive ever set up a RAID, and as close as I followed instructions ive still managed to fail at getting it to work, and id like to see if someone can tell me what ive missed..
EQUPIMENT:
Alienware m9750 (w/ newest BIOS)
Dual 250gb Western Digital SATA
Intel Storage Matrix Controller for RAID (Onboard)
In BIOS, I have RAID enabled for the 2 drives, everything is recognized properly..
After setting RAID there, I use the ISMC to set the raid array to RAID0 for the two drives, everything completes successfully. I pop in my windows XP Pro disc, it copies files, does everything, and when it gets to the first reboot to start the install it just keeps telling me " A Disc Read Error Occurred - Press CTRL+ALT+DEL "
I have set my boot order to
RAID - Drive 1
RAID - Drive 2
DVD Rom
What am I doing wrong?
And oddly enough, when I went back and made an attempt to undo the entire raid array, deleted it and set to no longer be in raid, and disabled it in BIOS, I get the same error when I try to install normally..
Any clues?
EQUPIMENT:
RAID - Drive 1
RAID - Drive 2
DVD Rom
Any clues?
