hokatichenci
- Oct 28, 2004
This is sort of weird, last night I noticed on my test array that I was getting 210mb/s writes and 170mb/s reads when I set it up with raid0. Now I have it setup as a rebuilt raid5 (8 hour rebuild weaksauce) and I'm getting about 130mb/s writes, and 110-115mb/s reads. The CPU is absolutely peaked out and might even be a real bottleneck here, but still - the write speeds have been significantly faster in each test with 8 disks. When I had only 4 disks, the read speeds were faster in each scenario. Does this seem weird to anybody else?
Code:
llama raid # cat /proc/mdstat
Personalities : [raid0] [raid1] [raid6] [raid5] [raid4]
md0 : active raid5 sdh1[7] sdg1[6] sdf1[5] sde1[4] sdd1[3] sdc1[2] sdb1[1] sda1[0]
2173866688 blocks level 5, 64k chunk, algorithm 2 [8/8] [UUUUUUUU]
unused devices: <none>
llama raid # ls
llama raid # dd if=/dev/zero of=1gbfile bs=1024k count=1024
1024+0 records in
1024+0 records out
1073741824 bytes (1.1 GB) copied, 7.86339 s, 137 MB/s
llama raid # dd if=1gbfile of=/dev/null
2097152+0 records in
2097152+0 records out
1073741824 bytes (1.1 GB) copied, 9.18942 s, 117 MB/s
1073741824 bytes (1.1 GB) copied, 9.37025 s, 115 MB/s
llama raid # dd if=/dev/zero of=10gbfile bs=1024k count=10240
10240+0 records in
10240+0 records out
10737418240 bytes (11 GB) copied, 82.4836 s, 130 MB/s
llama raid # dd if=10gbfile of=/dev/null
20971520+0 records in
20971520+0 records out
10737418240 bytes (11 GB) copied, 93.3376 s, 115 MB/s
10240+0 records in
10240+0 records out
10737418240 bytes (11 GB) copied, 83.7587 s, 128 MB/s
