Raid using my motherboard's onboard chip.
rxteenager
Hey there well I'm finally getting my feet wet with all this raid stuff. I have read about it a few times but I have never had the time/resources to set one up. Well I got two SSD's and I would love to set up a raid volume with them, I understand Raid 0 would be my best option for performance right? I don't care about reliability as I have all my files on two mirrored 640gb drives+backup.
That little mirrored setup is using the asus ez backup that came with my mb. I know my mb can do raid because it has the 10HR something southbridge. So here are my specs.
Asus P5Q Pro P45 MB
2x 128gb SSD's.
E8400
4gb DDR2 1000mhz
For now I don't really want to spend extra on a dedicated controller if I know my MB already has the capability of pulling it off. Well how much performance would I gain by buying a dedicated one. I would have a very small budget so I have to keep that in mind, I would be able to spend only 50dlls as a maximum. Would doing it with the on board controller affect performance? Would I even notice it?
The main purpose for my system is gaming.
Areca hardware RAID appeared to be limited to 70.000 IOps in an online review i seen once; that's something you might reach with only a few SSDs in RAID0. So onboard RAID0 has much more performance potential than hardware RAID; at those speeds you'll notice the host system having faster hardware than the dedicated Intel IOP chip on the Hardware RAID adaptor.
So yes, use onboard. :)
Set 128KiB stripesize; use Vista or Windows 7. Not XP.
