Raid stripe drives: problems reactivating.
robbob4
The only SeaTools tests I am able to run are both short and long generic tests on these 2 Seagate SATA 250 gig drives that I have in an enclosure together. These two were a striped set which I originally set up with computer management. I’ve had them running just fine (I would have to reactivate them if windows was running but would work fine from there) until I ended up unplugging one of the cables and not the other and has started this whole set of errors now.
Here is what errors I get when I try to fix the problem w/ computer management:
Plug in
Disk group GriswoldpcDg0: Disabled by errors
Volume Stripe1-01: Plex Stripe1: Plex is defined on a bad device
reactivate one:
Cannot be used to start volume
Cannot start Stripe1 volume, no valid plexes
Disk Disk1 in group GriswoldpcDg0: Disk device not found
attempt to reactivate the other:
INTERNAL Error - A disk group with the specified name already exists
(C100007A).
attempt to reactivate the "missing" drive:
no error just warning to run chkdsk after
unplugging & replugging the un reactivated drive:
no error, but now is considered foreign
importing the foreign drive:
INTERNAL Error - The disk group contains no valid configuration copies
(C10000B6).
Unspecified error (80004005).
And here are the properties of each drive (even though there are only 2 drives):
online dynamic 1: Bus Number 0, Target ID 0, LUN 0
offline or foreign dynamic 2: Bus Number 1, Target ID 0, LUN 0
missing dynamic 2: Port -1, Target ID -1, LUN -1
I have also tried deleting the registry key "primary disk group.reg" which did refer to GriswoldpcDg0 and I have also tried deleting all ghost drives that are present in hardware manager so windows reinstalled the drivers when I plugged them in. So far nothing has worked.
