TwistedMetalGear
- Jun 19, 2005
Just finished building my new system, and I was happy to see it boot up and recognize my E8400 without having to update the BIOS.
Anyway, I'm having trouble setting up a RAID 0 array with my two Raptor drives. The instructions from the Asus manual are as follows:
This is fine and all, except my BIOS has no "Onboard Serial-ATA BOOTROM" as mentioned in step 5. So all I can do is steps 1-4. I figured setting the IDE Configuration to RAID would be enough.
Then I press CTRL + I during boot as the manual instructs to enter the Intel Matrix Storage Manager Option ROM Utility, in which both of my drives are listed under "Physical Disks." Then I choose the Create RAID Volume, enter a name for it, select RAID 0 (Striped). The next option is to select the disks to add to the RAID, only it is grayed out and disabled for me! I cannot get into the select disks category and therefore I cannot set up the RAID array. What gives? As I said, the two drives are recognized by the main screen of the RAID setup utility, but once I try to create a RAID array it's like they don't exist anymore.
Any ideas? Does this have to do with not having the "Onboard Serial-ATA BOOTROM" option in BIOS? I want to get Windows setup on this thing but this is holding me back. Please help if you can, I'd appreciate it.
You must set the RAID item in the BIOS Setup before you can create a RAID set(s). To do this:
1. Enter the BIOS Setup during POST.
2. Go to the Main Menu, select IDE Configuration, then press <Enter>
3. Select the item Configure SATA As, then press <Enter> to display the configuration options.
4. Select RAID from the Configure SATA As item options, then press <Enter>.
5. Select the item Onboard Serial-ATA BOOTROM, press <Enter>, then select Enabled from the options.
6. Save your changes, then exit the BIOS Setup.
