RAID Sata and Pata?
Jinto
I have a PATA Seagate 7200.10 320gb (bought the wrong one on newegg awhile ago -.-"). Wondering if i buy the same drive except in SATA can I raid them? I have a Asus P5W motherboard. Never tried RAID before so would like to know. Thanks!
Linux software raid should allow you to do that. I know that nVidia's raid controller does it in 'firmware' as well. I do not know if Intel firmware RAID allows you to do it.
Im hoping to avoid software raid. Does anyone know whether this can work with the Asus P5W?
If I cant do it directly will a pata to sata adapter work?
Most likely. It does introduce another component, making the system more complex, thereby reducing the overall reliability. But that is the case regardless of whether you do cross-interface RAID or use an adapter.
